wheelsblank27
Almost finished rebuilding the c4 i bought cheap and have a couple unresolved issues I think...
1. When I removed the d20 tc from the np435 adapter that the po put in my bronco the spud shaft remained on the D20 and looks robe held in place by arubber retainer and some type of metal band ( looks like a seal on a dirt bike fork leg)
Will this spud shaft work when I bolt it up to e new c4, or do I need to source a new spud shaft and remove the old one ( hopefully not losing the 13 needle bearings in the d20 during the removal process) and how do I get it out... Remove that metal band and the rubber retainer?
2. How do I know if I have a j or T sle d20? Idk if the po installed this style shifter or it's stock ( I will post a link to my photobucket album with pics of my d20 shortly)
3.where can. I find a 164 tooth bell housing needed for my install of this 70's case fill c4? If anyone has one they might part w(budget style)please pm me, or a 157 tooth bell and torque converter.. I have a 164 tooth torque conv. 11 1/2" bolt pattern Already ,so tryin to use if possible.
4. How can I get the pilot bearing out of the crank without a puller or w/out damaging anything? Another member told me to pack with grease and use a prybar to wedge it out but idk how that will work if the bearing doesn't have room for the grease to get between so will probly be more mess than worth... Then again idk what I'm doin so what the h anyways.
I appreciate all the help I get and have gotten already
