Altmann
Just picked my 74 up on Friday and changed the oil and battery & terminal ends.
Quick specs: rebuilt 302 with C4 transmission, 2 barrel carb, drum brakes.
There are a few things I've been wondering about and I wanted to ask your opinions on:
pinging leaf springs? when I am backing out of my driveway and occasionally on more intense bumps (think speedbumps) I get loud metallic clicks. I asked a friend he said it's likely my leaf springs rubbing, and suggested lubing them with lithium grease and gave me a spray can.
Is that something I should do? I'm OK with it if it's purely a noise issue but I also don't want to just start spraying stuff onto my bronco without knowing the consequences.
Running speaker wire: I have a bare metal interior (no carpet or rhinolining), I am probably going to stick a couple speakers (either in small boxes in the back or in the doors), I'd like to change as little as possible, but where do you gents run the wires? If you did it into the doors do you cut holes and use grommets or flex tubing between the door and front panel? For rear speakers (if I decide to) I imagine I'm stuck with just running them through the interior?
This Saturday I'm going to do a full runthrough on the truck, put her on a lift, take the wheels off, etc. So anything I should keep an eye on our look out for?
Thanks again and I'm so happy to have a great bronco!
