Some of you have followed my 351 upgrade debacle for the past five years. I'm obviously taking my sweet time on it these days, but am back on track. I've scrapped the last engine I was trying to use and have purchased a rebuilt 1995 351 with all paperwork from the machine shop included by the guy I got the engine from.
Being a 1995 engine, it is not a roller block. However, when it was rebuilt, it was upgraded to a conversion roller cam (Comp 35-412-8) as well as a set of roller rockers.
Before I bought this engine, I bought a set of AFR aluminum heads in anticipation of building the engine I wanted.
My first question is it worth the time and effort to swap out the 1995 Ford heads for the AFR ones? I believe the 1995 heads would be GT40s, but I'm not sure of that.
If I end up swapping the heads, do I need to go to the extent of removing the valve springs from the stock heads and swapping them over to the AFR heads? The AFR heads came assembled with springs, but I don't know if the spring rate is accurate or appropriate for the cam that was installed with the rebuild.
Would swapping the heads require a different length of push rods?
Pictures of both the Ford and AFR heads as they currently sit:
