A good sound deadener.
cs_88
So I've got my door panels off right now, and I'm thinking I would like to install a good sound deadener on the inside of the door skin to help with that tin can sound. It seems like there are a lot of possibilities (self adhesive sound mats, rubberized undercoating spray, beadliner spray etc.). Just wondering what you guys think would be best for inside the door.
Baja71
The most effective options are going to be designed to reduce sound, which bed liner isn't. Dynamat and similar products are ideal for inside the door. Whatever you use, make sure you assess it's moisture absorbency quotient. Weight is also a consideration.
70EB
Gig Harbor
Just put Dynamat inside mine (along with most of the interior). Thousand times difference is the way the doors sound. No tin can. If you tap the sheetmetal on the outside, it has a solid sound and the door shuts with a solid thunk.
Search online and you can find it much cheaper.
kaw550
Your post said "good"
If price becomes and issue you can use a product called Peal and Seal from the Home Depot. It is not as good as Dynamat but it is cheaper. I have also heard it could make the car smell a little like tar but I never noticed.
I have also used eDead
http://www.edesignaudio.com/product_info.php?cPath=1_24&products_id=55
And I have also used Hoodliner from Dynomat (I used it under the hood and whatever was left over was hidden in the car.
cs_88
cs_88
Now thats what I'm after.
fordguy
peel and seal does the same thing, now it may not pass the db test by cutting as much as dyna but for the money it does great.
moneypit77
forks, WA
I found dynomat on ebay for a hundred bucks for the bulk pack wich is about half the price from most venders. still need one more but 2 of these was enough to cover the hardtop,front floors (from under the seats forward), the door panels, the rear quarters, and wheelwells. one more would get the rear floor. hope this helps Casey
Pa PITT
Stephenville TEXAS
Will this dynomat be what I NEED to help with the noise in my 4bt swap...I suppose it would be better to put the dynomat under the carpet instead of between the motor and firewall...Is Ebay the best place to find the Dynomat.
fordguy
use the peel and seal for pennies on the dollar compared to dynomat. running buddy has it in his street rod, he had dynomat last street rod. the cheap stuff works. you can thump on his current rod and get the thud someone talked about earlier. unbelievable difference, but if you must spend the money of course dynamat will do good also.
phred
Earth
Yeah I agree with the peel and stick. I bought a roll 12" wide and about 30 feet long for about 20 bucks. Good size for going inside doors behind panels.
blue bronc
Fort worth
the PO sprayed the floor with rhino i made sure to fix the bad spots.
I layed dynamat extreme over the rhino sprayed with epoxy primer then put line x over that.
Sold as a rock no sound and heat does not come thru
Hal9000
Flagstaff, AZ
There's also a product called "fat mat" that a bunch of people on the Mercedes forum I used to visit loved. If I remember, it was cheaper than dynamat by quite a bit. Never used it myself.
What section of Home Depot is peel and seal located in? Roofing would be my first guess but I'm sure that I'm not the only one who doesn't want to wander through the whole place looking for it.
stock74
I installed dynamat extreme in the doors on my bronco and it made a huge difference. As others have said, the doors no longer sound like a tin can and instead close with a thud. The doors also have a nice weighted feel to them too, making them feel more solid. I know dynamat is not cheap but I would have to say that atleast in my experience with this product it was definitely worth the extra money.
Tuff68
Hermitage, TN
I used the Fat Mat on my 72 and it has worked great.
You can get a 60' roll of Fat Mat for less than the price of a 36' box of the DyMat.
The best thing I did was covered the inside of my top before I put the new headliner back in. I can not tell you how much of a change it made. If you tap on the top now it sound like you are tapping on wood.
You can find the Fat Mat on E-bay and just get there number off there to call and order direct. Both of my orders came in within 3 days.
66broncofan
Southern Colorado
QuietCar
I was just given this product to try out on my 66. It is called quiet car. Reviews look pretty good. Not cheap, but not crazy expensive. check out http://www.quietcoat.com
sprayable, rollable or brushable. Good for road and engine noise, or body vibrations etc.
I plan on using it on my hard top, inside doors, as firewall sound insulator, undercoating, etc..
moneypit77
forks, WA
one thing to consider is there is some cheap stuff out there but there could be drawbacks, heat for example if you put it under the headliner or inside the door will it stick once it sits outside and bakes in the sun? I dont claim to be an expert at all and just wanted to throw that out there because pulling the headliner out just to reattach sound deadener or even to replace it would not be very fun with my roll cage in the way, Ill stick with tried and true even for more money, of course you could also do it right the second time;D casey
TXHusker
Edmond, OK
if it isn't too late for this post....
I read this a couple weeks ago and asked a buddy who builds custom street rods. He uses products from SecondSkin Audio.com He has been real pleased with their product.
Hope this helps
deltarat
Drew,Ms
You put LineX over dynamat? I would not think the LineX company would do that. Did they give you a guaranty on it? I thought about putting the dynamat over my epoxy primer and then LineX , but I didn't think they would do it or how it would work.
