A-Pillar / Driver door pillar hole ? ?
Izzy_Britton
Does anybody know what the real reason is for the hole at the top of the driver side door pillar is for? there are is also a large hole in the top of the driver side kick panel that seems to go no where.
I purchased a new door hinge pillar and kick panel this week. the hinge pillar has the hole in it, but the kick panel does not.
real reasons? i thought maybe for wires but wires to what?
rpmgarage22
Yessir.
It is for your ambient temp sensor. It was an early emissions device that used the “sensor” to retard/advance timing.
Try a search for it on here.
Here is a pic installed by AZ73...
I
Izzy_Britton
Thank you sir! Now I know that I can weld that hold up. Been meaning to ask for a could weekend now just kept forgetting.
I looked thru many build threads and boat loads of pictures get never saw another one. Then the pics at wild horse for the replacement part shows no hole. When I got it yesterday morning I was a little bummed.
Thank you again
What year is yours Izzy? A '72 or '73 perhaps (most likely)?
I think those were the only two years that actually used the part (maybe even '73 only) but the hole was there longer, but with a simple rubber plug/cap inserted to close it off.
Not sure if the other Broncos also got the kick-panel hole, but you see a lot of Broncos with the plug.
The later years also did not have the screw holes. Just two dimples where the screw holes would have been, like yours has.
That's usually how you can tell if a Bronco originally had the sensor. The screw holes were there.
Oh, and if you have not already seen it, there is a thread with "Mind Your P's and Q's" in the title.
If yours happens to be a truck with a P or a Q in the VIN, pop over and add your info.
Thanks!
I
Izzy_Britton
@DirtDonk: thanks for that info Paul. You are correct, 73. these bronco things are full of oddities arent they? I dunno nothing about the P and Q vins yet, i will read up on that thread when i find it.
I think i will keep with the plan to weld the hole up.
@mikee73: I had not considered using the hole for a dome light, I was kind of under the impression that these things not only didnt have a dome light but that they didnt even have a provision for one. I did give some thought to adding a 'dome' and 'map' lights to the roll bar, but had not considered HOW yet.
I am contemplating doing power windows, so i may drill holes lower down in the door.
I
Izzy_Britton
so are you saying that the kick panel hole might have been for something ELSE? its huge for a single or 2 wire ambient temp sensor i think. oddities! more and more.
I also have some funky tiedown loop/hole thing under the left side rear inner fender, spot welded to the underside of the body. i accidentally cut it off when removing the rear quarters and inner fenders and fuel filler kickout pieces. obviously unused from the gitgo but had me scratching my head when i realized i cut it off. lol odd little boxy 4x4's.
MikeCon
My early 73(11/72) just has a plug.
Nope. Just not sure why it was so big either.
We gotta see that! Did you take pics?
I wonder if a PO had covered up the oval hole where the old EVAP canister went, behind a panel at the driver's left shoulder area.
I
Izzy_Britton
The PO kept the evap stuff behind driver shoulder intact. I removed it because it was not hooked up. I keep the parts. No plan to reinstall. There was little vent caps on the fuel tank vents.
I will get photo of tie down hook/hole this weekend. It appears to be factory installed but I still know better when I get it cleaned up a bit.
