A9L computer?
blazinchuck
hey guys, I took the 5.0 EFI out of FBG...to install on our 77. my bronco had a 435...so when I bought the computer, I got the manual A9l. my question is...can I still use this with the 77? The 77 has a C4??
I saw the 2 connectors on the RJM harness, but the site said you have to connect those according to which computer you had(not which trans your running). Any thoughts would be great. I really hope I dont have to swap the ECM out for another one.:p
rtj731
//http://www.classicbroncos.com/forums/showthread.php?t=147975&highlight=RTJ731"]http://http://www.classicbroncos.com/forums/showthread.php?t=147975&highlight=RTJ731[/URL]
Chuck hope this helps
blazinchuck
blazinchuck
tenfo...looks like thats what i needed to know-thanks rtj731! i hope so...planning to fire it up this weekend! Tomorrow will be one week since the tear down(removing the 306 and stock harness...to install EFI and centech.
one other issue I will be facing...on FBG I used a explorer air box assembly w/mass. I cant reuse this in this 77...I just need a air tube to install my sensor and a cone filter for now. Any stock vehicles that would work or have the tube i need?
Viperwolf1
electron whisperer
hey randy...i have the centech harness and rjm...centech says to take the start wire and run it through(in/out of) the NSS and back to the solenoid. this is what i did, so it will only crank when in park or neutral. i should be ok with this ...i hope
what did other folks use for the inlet tube and cone filter??
You have the NSS wired correctly for the C4. It doesn't really have anything to do with the EFI wiring.
I went to the wrecking yard with my tape measure and found a tube that was shaped close to what I needed and had the correct diameter. This one is from a E250 w/7.3.
blazinchuck
blazinchuck
i was gonna reuse the tube i have...not sure if the MAF housing(stock explorer air box) will have a inside tube(big enough) to clamp a filter on
whats the second stainless cable going the the throttle body?? cruise or kick down? my bracket is on the other side(firewall) and using a bcb throttle cable
does anyone have a easy idea for the c4 kick down??
