Ac
That specific compressor, no adapter needed. Already has the screw on hose fittings.
ba123
CA
So you're trying to find a new compressor to replace that one you have, correct?
Can you show a pic with the whole label?
Is your mount a Ford Explorer mount or something else?
ksagis
Aspiring Bronco Guru
Austin
ba123, yes, correct in that I'm trying to identify replacement part number (and preferably original vehicle it was installed on since I often find that easier to use when sourcing parts)
Pic attached of label, this is a Foxbody 5.0 with Exploder front end. I assumed that the compressor was from an Explorer given the same bolt pattern. But then I noticed my setup didn't have the line adapter bolted on back of compressor and thus started the rabbit hole. The rabbit hole started with my post (#17 in this thread) of the Sanden SD7H15 model 8105 that looked visually identical. I am starting to think the Sanden SD7H17 came in different configurations of lines attachments maybe from poking around some more.
Here's a few bits of info:
Using one of the vehicles from that same post (#17) from my AI search, 1994 Ford F-250, 5.0 from RockAuto shows different host connections (most needing the adapter like lars posted).
The only one that looks that same as mine (with fittings part of the part as delivered) seems to be the Four Seasons 58581
Just feels weird to me that only one of the compressors (for a specific vehicle) on the Rock Auto site has the fittings already on it, but all the others seem to require the adapter. Which goes back to how to best source a replacement compressor and the rabbit hole.
ba123
CA
traveling and hard to search right now but if I had to guess, I would guess that the person who installed it found something that would work and then custom made the hoses with those ends.
If it were me, and I had an Explorer front dress (which I do), I would use an Explorer compressor with the adapter (and I do as well) and make new hoses but on the other hand, you rarely have to change a compressor and if the hoses are tough then keep trying to find the same. My main fear in matching what you have is that it might not be perfectly aligned on the belt side or maybe the mounting holes were drilled out, and you might have other issues with a new version.
ksagis
Austin
Agreed on all, I may buy a compressor at risk to avoid risk of remaking lines.
ba123
CA
Yes, it looks like it is the same as the Four Seasons 58581 and might have fit the Foxbody 5.0 Mustang as well as the earlier Explorer.
If it were me, I'd get that Four Seasons one and see if it fits.
I did find the Manufacturer's site for the one you have but their site REALLY sucks. (https://uacparts.com/Home/Index)
If you find a part number and Summit carries it, that is the best to see what the Applcation is:
(and not sure why it says that but click it and it still works)
ksagis
Austin
@ba123, thanks for above, you are right, the UAC site totally sucks.
For the life of me, I can't find where the part I have is on the UAC site. Can you point me how you found it or share a direct link?
Edit, I dug around with coffee assist and found this using for "search for NA parts" function but the 4628 search returned a slightly different pn (7416). Not sure what the fittings on back are? Maybe pressure taps? Starting to wonder if UAC discontinued the 4628 part.
Edit 2: found this but decal looks different but part looks the same.
Appreciate pointing me at UAC site.
ba123
CA
Sorry, I don't think I was successful finding it either but the one you found looks right. And same "model" number.
No idea what the difference is between their model number and part number.
fordguy
I used an sd7 and the BC broncos adapter. Will get a pic.
