- Nov 28, 2011
- 791
I just put a new carb on and the accelerator pump is really stiff. The spring on the throttle linkage is not even close to strong enough to press it. Is there a way to fix this? It's causing the engine to bog pretty badly when I press the gas and it will work just fine if I press the throttle and pump at the same time.
