- Aug 27, 2001
- 5,147
Stock 75 Bronco....New rebuilt 2150 motor craft carb. I noticed that it wasn't starting so I used a little starter fluid and it fired up. After setting overnight you have to prime the carb with fuel or starter fluid. I looked...and the accelerator pump arm was not actuating the dowel/rod that pushes in on the pump. That dowel won't push in at all......even by manually pushing on the pump arm. I also noticed for the second time that the accelerator pump was leaking from the weep hole under the arm. I pulled it apart and sure enough..another ripped acc pump diaphragm . Put it all back together with new diaphragm and tried it with no fuel in it and the dowel pushes in just fine when u push the throttle arm. After remounting it all...I tried it all again and when it gets fuel to it...it gets hard to push again. The throttle arm goes all the way back like it's supposed to. I pulled it all apart and replaced everything with a new kit. Cleaned all ports too. Still doing it.
Any ideas?
Andy
Any ideas?
Andy
