The acid dip works well but unless you go through the dip and soaking neutrilization steps and then on to E-coat all in the same process you will end up with issues in the seams. The standard method of dip, high pressure rinse and heated dry leaves you vunerable in the seams should they see moisture again. Out here in California the dip tanks create a huge amount of Hazardious waste but nothing like the neutralization and rinsing tanks would. Then there is the water issues and aditional permits for painting and hazard diaposal. For a full process you may have to look to Arizona.
In my personal prep work In the seams after sand blasting them I mask off around the seam and take por and thin it way down and blow it in with an air brush fludding the seam and forcing it in as best as I can. On replacement pannels I epoxy prime them first and fit to the install then remove the pannel and put in my weld holes Then I put the pannel back in place and just before welding an spot sand blast each weld location.
As for soda blasting I dont think it will remove rust or former repair material.
If I had to pay for stripping I would sandblast with someone who knows what they are doing. I would sand blast everything except the outside door skins, the hood, and the top skin of the hard top. Those parts are most vulnerable to warpage. Then can be easily handled buy properly masked off aircraft stripper.
