Added the hellwig front sway bar today
bmc69
I need to put one on front of my '78...not sure if the Hellwig will work. Pics?
eaglenest66
Installed on my 74 this past winter! Big difference with the 2.5' SL and 31x10.5x15" tires. Drives like a modern day vehicle.
asappin
Quick disconnect or not? Let’s see pics. I’m thinkin about doing the same
1strodeo
Squirrel Watcher
Wisconsin
Just looked at prices Holy smokes!!!:eek:
Does something like a 3-way adjustable draglink serve the same/similar purpose?
bronconut73
Completely different animal.
Drag link is the link that goes from ps box to the tie rod.
Anti-sway bars reduce sway in corners, by attaching the suspension from one side to the other side, forcing them to act together. This reduces sway. Stiff bar, less sway.
broncodriver99
Glen Allen, VA
I am running one on my '73. It did stiffen it up considerably. Do you have any pics of the lower brackets? Mine is one of the early ones and I didn't care for the lower bracket setup and the way it cocked over the spring cups. I opted to make a set of brackets and weld them to the radius arm caps instead. I heard they changed the lower bracket setup to help minimize the issues with the spring cups.
1strodeo
Squirrel Watcher
Wisconsin
IIRC from past threads the Bronco front sway bar is pretty rare, but can one be found on other old Ford trucks? I’m guessing No because I don’t believe the Bronco shared a chassis with any other model?
sykanr0ng
I’ve noticed that, and now I know why...aftermarket go for $700+!!!! :eek: for a freaking sway bar c’mon man!!
For a product that is made to fit a rare and long out of production vehicle?
There were less than a quarter of a million Broncos made from 1966 through 1977 and how many of them still survive?
Small market + high quality product = NOT cheap.
bronconut73
for a product that is made to fit a rare and long out of production vehicle?
There were less than a quarter of a million broncos made from 1966 through 1977 and how many of them still survive?
Small market + high quality product = not cheap.
/\/\this/\/\
