adding additional ground straps to bronco
buckstone
los angeles, ca
have a 76 bronco. currently, the neg battery terminal is grounded only to the engine (to the belly of the c4 tranny, i think). would like to add addtional ground strap/wires from battery to chassis and from engine (tranny) to chassis. any recommendations as to where on trhe chassis i can/should make these connections?? for the battery connection, looks like the frame where the stock bumper connects may be the best/closest spot. how about from engine to chassis? thanks.
SaddleUp
Vancouver, WA
Since your starter creates the greatest pull on the system you will want the primary ground to go directly to the engine block (Not the tranny). Then you will want a strap going from the engine block to the body. (There should be one there already)
Then if you want additional ground straps add one going to the frame and one from the frame to the body. There are any number of holes in the frame already (some threaded) that would make good ground spots. Just find one that is also conveniently close to a good ground spot on the corresponding item your connecting to.
Gummi Bear
That's actually my project this weekend. My Bronc isn't moving for a while, so I'm gonna put in my straps. I scored a handfull of straps from a buddy, so I'll install a ground bar on the fender, and bond the body, frame and motor all to the bar. This'll also give me an opportunity to hit a good solid ground whenever I need it. I'll also send a bonding strap from my CB antenna to the frame for the 'mo betta' grounding plane...
Do it mon, you'll be glad ya did!
astark
Bronco God
I would love to see some pics of deluxe grounding if anyone has them or is in the mood to take some.
B
buckstone
los angeles, ca
ok - i've got the battery grounded to engine block and body. another ground from block to body. any more recommended?? what about the frame? thanks.
70_Steve
Old Guy
I've got my negative battery cable fastened to the block. I have one smallish ground strap from the back of the intake manifold to the firewall. I also grounded the frame. My stock gas tank sending unit grounds to the frame. I also use the frame as the ground for my fuel pumps. I installed a huge strap from the frame as I intend to run a winch at some point. Used the same point on my engine block as I mounted the negative battery cable.
Gummi Bear
Sounds like ol 70Steve's off to a good start.
Yes, bond to the frame. Also put in a jumper to the cage if you have one. Be good and sure to clean your contact areas where the strap fastens to the body, frame, etc, and coat it liberally with dielectric grease. Eventually the grease will wear off, but it will make your connection pretty good for a long while. Just like checking your wiring once in a while, check your bonding straps, and make sure they aren't crudded up. Clean the connections if you need to.
SaddleUp
Vancouver, WA
Another oft missed grounding point is the radiator if your using an aluminum one. Especially if your running an electric fan. Keeping it grounded well will help prevent corrosion in and on it from what I understand. (Don't ask why as I don't know the details beyond the fan creating static electricity)
SaddleUp
Vancouver, WA
buckstone said:
ok - i'll run a strap to the frame somewhere. i've got a 76 bonco, stock radiator. is this aluminum? with electric fan? thanks.
No, the stock radiator isn't aluminum. I mentioned it since it is fairly common to replace the stock one with an aluminum one. Since you have an electric fan on it you might want to go ahead and run a ground wire to it although I do not know if it will make any difference with a stock radiator. It would be a simple matter to run a 14 Guage (or so) wire from one of the shroud screws over to the top radiator mount on one side and even if it isn't necessary it also will not hurt anything.
j.r.nice
almost as important as how many grounds, is how big a ground strap? I would use at least "0" or "00" gauge. Not hard to make to custom length.
