Adding Chrome Grill Trim...
nickmyron
Tigard, OR
I was hoping I could get some advice on adding the Chrome Grill Trim to grills that did not previously have it.
Chrome:
http://www.tomsbroncoparts.com/product.php?category=6&id=1193
Clips:
http://broncograveyard.com/bronco/i-15195_1966-77_grill_trim_clip_package.htm
So are there any tricks to drilling the holes in the grill for the clips in the correct location? Anybody have any measurments or anything? How difficult is it?
3469%3A3%3B99%7Ffp33%3B%3Enu%3D3233%3E5%3B9%3E%3A64%3E23245%3B9%3B55565ot1lsi
Any help is greatly appreciated.
Thanks,
Nick~
nickmyron@hotmail.com
silverbullet
Columbia, MO
Nick,
Never installed on myself. My original grill had one but had to replace it because of rust. I would imagine if you had a trim piece in hand than proper placement could be figured with were the bolts are on the trim. Not much help but I am sure it can be done. Good luck.
Dave
71 SPORT
LAKEWOOD COLORADO
I would assemble the trim,tape it in position in your grill. use a sharpie to outline the trim (both inside and out)and drill the holes in the center of those 2 outlines
bowhunter
The only thing you really need to be concerned with is that your width and height of the holes are correct, as the clips move inside of the trim.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Exactly. I have a sport grille with the trim removed and the holes are pretty evenly spaced around the edge. They don't have to be perfectly located as the clips slide inside the chrome.
