.. Bulldog I thought that what you were asking. Yes the chrome can be added. I think the kits have instruction with them. But ask lot of questions.
I guess I'll say .. Measure twice & drill only once. But I believe you drill some holes & Add clips & trim screws ..
.. But most body guys use masking tape .. Under the trim .. Lay down a bead of tape from one end of your Bronco to the other. Sight down the tape to see if it's straight .
After you've spent 30 minutes looking at the tape too make sure it's straight .
You might be ready to drill holes.
... I Guess I CAN SAY .. You can tape each piece of chrome trim to the side of your Bronco & Tape it down & see if it straight .. Stand back & look at it. Does it not have any waves. THEN DRILL.
.. HOPE THAT HELPS.
