Additional things to take with Explorer motor
Ed74
San Diego, CA
Hi everyone,
I may have a lead to pick up a '96 Explorer 5.0 motor this weekend. I was wondering if you guys can help me out with some basic questions:
1. What misc. things should I take, in addition to the motor? ex. sensors, hoses, wiring, etc. I would hate to return back to the seller to pick up forgotten items.
2. If I only plan on removing the intake, Serpentine set up, and heads, do I need any special tools/pullies to acquire the parts?
3. Any good advice on how to pull an engine? I have never done it before and I would greatly appreciate any info.
Thank you,
Ed
73stallion
Eugene, OR
if you just plan on taking the front dress, you'll probably need a harmonic balancer puller. if it were me, i'd just yank the whole thing and the harness. what about the trans, is that available too? also, does it have hydroboost?
iwlbcnu
WHat a PAIN!!! I just stripped a 1996, took a day to get the engine unbolted, every bolt was a pain to get to and get loose. Pulled the engine and dropped the trans in a couple hours the next day though. The main engine harness connects to the trans so to pull the engine I had to completely pull the harness off the engine. Remember it has the good GT40 heads so grab the whole engine.
E
Ed74
San Diego, CA
Wow that bad hugh? Any additional advice that will make removal of the engine any easeir? I will probably begine removal of the engine around 2pm, therefore every second of time spared will be helpful before it gets dark.
Thanks Iwlbcnu and Ben for your help
iwlbcnu
You need small hands to get to anything. I had to remove the upper intake to get to the top bell housing bolts, to get it off I had to jack the trans so the rear bolt would come up past the firewall. The 2nd from top on the drivers side hit the firewall but came out enough for engine removal. The fan takes the special tools, I had to borrow them. It was easier to remove the ehaust from the first joint than the manifolds.
E
Ed74
San Diego, CA
Thanks for the good info! What type of tool do I need to pull the fan off? I do no want to ding or bend it while removing the engine.
iwlbcnu
It is a special tool that is a big flat wrench and then a big fork wrench that fits over the bolts on the wp to keep it from spinning. I have only done 2 and both were a PITA. It is supposed to be real easy. The Explorer is standard right hand thread. Look here, http://www.mytoolstore.com/kd/kdengi06.html
iwlbcnu
I doubt it. It was a fight with the tool. I still had to remove the fan to clutch bolts to get enough room, but my fan wasn't a tad bent too. I think Autozone will rent it to you.
E
Ed74
San Diego, CA
Once again, thanks for the terrific info! I will keep you informed regarding the progress of my engine.
