- Jun 21, 2007
- 10
City:
Dallas,TX
Price: $ 500
Price: $ 500
Advance Adapters 50-2704A
AODE / 4R70W to BRONCO DANA 20 T/C
Bought this kit and then decided to go another route. Has not been connected to a transmission or seen any action.
Bought for $700 , selling for $500 shipped.
_______________________________________
AOD LATE/BRONCO DANA 20 T/C USING THE STOCK 4WD 31 SPLINE OUTPUT
Ford AOD adapter to the Bronco Dana 20 is 7.40" in length. The adapter material is 356 T-6 heat treated aluminum alloy, and the adapter has a provision to retain the original early Bronco mount. The adapter kit includes an adapter housing, spud shaft, retainer, bearing, snap ring, gasket, seal, o-ring, fastening hardware and adapter instructions.
Transfer Case
The adapter assembly will fit any 1966-77 Bronco Dana 20 transfer case. T-style transfer case shifter linkage is required.
Transmission
This automatic overdrive transmission has become very popular among Bronco owners. The gear ratio found in this transmission is great for trail and highway use. We manufacture adapters for both the early and late model AOD transmission. This transmission assembly is longer than the stock V8 assembly. It requires relocation and modifications to your stock crossmember. The "T" handle transfer case shifter is the easiest linkage to use, having only minor modifications. The "J" pattern can be used - but with a little ingenuity. The adapter kit comes complete with an adapter housing, main shaft, spud shaft, bearings and seals.
Bill Of Materials
Transfer Case
Transmission
Bill Of Materials
- ADAPTER- AOD TO D20 BRONCO / 51-2703
- ADAPTER- BRONCO D20 TO AX15 / 51-9920A
- SHAFT- ZF TO BRONCO D20 SPUD / 52-4303
- SLEEVE- BRONCO 20/C6 XMEMBER / 716042
- RETAINER- D20 BEARING FOR BRONCO / 716223
- BEARING SEALED 307 / 716302
- SNAP RING / 716455
- BRONCO TRANSFER CASE GSKT / 716513
- O-RING BRONCO INDEX RETAINER / 716714
- SEAL C/R 21064 / 716764
- AOD KIT BOLT PACK / 714206
- STUD BOLT 3/8 -16 X 3-1/2 GRD B7 / 723712
