I believe that would be correct.
The standard EFI version of the tank is designed around a typical Ford (Mustang mostly?) pump, which in most forms is capable of 90-110 psi (depending on brand and model most likely) and enough volume for most modest needs.
The good news is that even if you needed more volume you can easily find the upgraded pumps in that category. They fit right up and wire the same.
I think 255 liters per hour is the typical aftermarket rating for the standard-duty pumps, which is a little more than a stock one? Unless you're running a really hot engine then, i don't think you'd need more.
Haven't looked at that on their site in awhile, so maybe it's not easy to find. But it's there somewhere. I don't actually remember if they do the A/N fittings or not. I'll have to look at mine, but our Sherman automatically comes outfitted with them, in case that becomes an issue with Aero (which it shouldn't, but wanted to throw a plug for our stuff anyway I could!%));D and you can't get it the way you want.
Bunch of us are running them with and without EFI out this way, so it can't be too big a deal.
And speaking of which... Whereabouts are you located?
