air cleaner filter size
meathead333
Alexandria, VA
i had to get a smaller air cleaner filter so it would fit next to the new dizzy i put it. i did have a 14" and i think i ended up with a 10" in there now. is that a big deal?
sprinksbeme
Kingman, AZ
I run a 10'' also but found that the 10" X2" was to restrictive and robbed power went to a 10X3.5" and ran better than ever. Tryed it because sons chevy Pu uses the 10" x 3.5" element.
Marty
SteveL
Huge chevy guy
Hawthorne ca
I run a 10" by 4" in my 72 and it works ok. On our 66I tried to use the 10"x2" with the high flow top and it didn't provide enough air. Both broncos have a 351w in em. I also have dizzy clearance issues w/ a DUI. I ended up putting an edelbrock elite triangle and it fits and works great. I just turned it a little to clear the dizzy. Now I need to get another one for the 72 so I can put a stock hood back on it.
jim71
Sprague MB
I had a 14" cleaner on my old 302 and had to change to a smaller filter when I swapped in my 351 since I upgraded to a DUI distributor. I got a K&N XStream filter (read lots of great reviews about em)... 11" I think, but I can't remember for sure. Flows plenty of air. And hey, if the guys on Overhaulin' use them on all their big blocks, they've got to be OK.
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
14 inch x 3 inch drop base on Edlebrock with MSD Pro billet (wide) distributor. Just clears. No problems.
73stallion
Eugene, OR
here's what i'm running. it's a 9x2 K&N with an x-treme top. i'm running 348 horses at the crank, it has no problems with it.
meathead333
meathead333
Alexandria, VA
i went and got a 10"x3" filter. it sits really high obviously. the filter sits and pretty much fills the hood scoop, i had to get rig of the wing nut and add a washer and nut becaue the top of the scoop hit the wing nut. it that a bad thing if its that high in the scoop for the air flow or what not?
BG's 68 Bronco
WOW :eek: that is a nice engine. Spic and Span Clean ;)
What do you mean by drop base?
BoltBuster
I have a Ford Motorsport 13", with 2" drop. Just misses the MSD Distributor.
joe
i went to a local speed shop and got a recessed and offset air cleaner for mine , it a 14 inch and I got a DUI. I'm going to get another digital camera today so mayby I'll get my contributor status and post some pics, Hell, I cant even figure out how to post a link but heres the web page address [/URL]
www.500ms.com
hey, it worked
shifter
Agua Dulce, CA
I used this one from cool blue when running a dui and carb, 10" dia. cant remember if it was 3 1/2 or 4" tall. With 2" body lift there was 1/4" clearance from the hood.
