Air Filter/Assembly Choices
Lonestar
Austin, TX
What after market air filters are you all running? and how do you like them. <br><br>I have no body lift (stock 2 brl carb.) ... What will fit under my hood, look good and alow my engine to breath well.
O
Original77
Guest
My truck is completely stock, I'm able to run a 14 inch x 2 inch round chrome, and still close the hood. Some people are able to run a 14 x 3 with a drop base. I'm still kinda partial to the factory air cleaner though because it has the cold air intake coming off the grill. I run the factory air cleaner during the winter because it also has the carb preheater hose and run the chrome dish during the summer. o'77
74bronc
I run a 14X3" drop base chrome K&N filter assembly that I got from Summit Racing. You will probably have to have a drop base air cleaner to clear everything. I can now hear the carb sucking when idling at a stoplight, which I couldn't hear before with the paper filter. I personally think the K&N is worth it because I can keep cleaning it and re-using the same filter. I think I paid around $60 for the whole setup. Looks nice too!
mark74ranger
Albuquerque N.M.
I have a Ford Motorsport drop-base chrome cleaner. It is 13" in diameter and gives a little extra space for the large diameter distributor cap. I use a 13X2.3" K&N.
Broncmeister
14X3 here too, the only thing I don't like about the open air cleaner is it that it can get wet when you are driving through a 5 foot deep river :). This spring we had a pretty heavy rainfall and the wind blew just perfect to send the moisture through my grill and sopped my air cleaner while it was parked.
