Air box, air filter assembly from a Ford vehicle for custom air intake setup. The box has a flange inside of it that will accept the common 4 bolt flange 70-90mm MAF sensor. There is no MAF sensor inside the box right now, I used it on my Bronco with a different air box. The air inlet is facing down so a cold air intake would be easy to do with an enclosure on the bottom. This box fits fairly well in a Bronco in the stock battery location, or can be moved to the driver's side as well, see last pic showing it in battery location.
$35 for the air filter box.
Also have the rubber boot shown in 2nd to last picture that works with the box and get's you 1/2 way to the intake and necks down to the common 3" intake tubing size from the larger diameter at the box.
$15 for the rubber boot.
