NC-Fordguy
Guys.....
During steep incline trail rides I'm still seeing temps that I don't like. At 220 degrees I shut it down during our ride at Mountain city Tennesee. A few minutes of cooling with the hood open and start up to cycle she did fine the rest of the way.
The specs..
302 rebuilt .30 over, crane rv cam, ported stock cast heads
C-4 rebuilt with shift kit, stock converter and 30k pound cooler mounted in front of the radiator. 4.56 gears pushing 37's with terra low gears in the case.
Things I've done over the years..
BC Broncos triple pass radiator
flow kooler water pump
160 degree thermastat(180 and 195 didn't help, actually made things worse)
Ceramic coated headers
shroud and stock fan
Small electric pusher fan(maybee 800cfm)
Recovery tank
Water wetter
Each one of the upgrades has helped as it takes longer to hit uncomfortable temps but eventually I see the temps I don't like.
It seems to me I need to find a way to increase the airflow at crawling speeds as going down the highway at 65mph it's always sitting at 160 degrees even when it's 100 degrees outside.
You all think it would be a good idea to ditch the mechanical fan and install a taurus fan or something similiar??
The specs..
Recovery tank
Water wetter
