Air Ride Body Mounts??
bknbronco
North Metro, MN
Anybody ever seen a bronco body mounted on top of air coushins like a semi is? Seems like it might be something that would help these bucking broncos?
Or maybe just putting the seats on something similar would help?
On bumpy roads i have to use my hand throttle or the bumps make my foot bounce all over the pedal and makes them bumps even worse! Im tired of looking like a bronco bobblehead on some of the roads around the house!
Body on air won't work. The body needs the frame for structure. Try and air it and the door gapswill never be right and you will be finding body cracks real soon. Semi's can do it because they are structured to be that way.
Seats, that has been done since the 60's. Bosen(?) were used on the early race broncos. They were a suspension seats from a big truck.
B
bknbronco
North Metro, MN
Yes good point! Youd need basically two frames to make it work. Scrap that idea.%)
I found that if i tighten my lap belts really tight it keeps me from bouncing too badly.
B
bknbronco
North Metro, MN
Better shocks maybe!
Doubt it! Probably taking them off would be the best bet! Leaf springs just suck no matter what you do! Its old school leafspring suspension that sucks. That and the roads around here just plain BLOW! Even my cadi rides rough on some of these buckled sideroads.
lowbush
Summerland Key, FL
The Range Rovers from I think 92-01 have an air bag system, basically the coils are swapped for bags that fit in the coil buckets, they did not get the kinks worked out until 99 or so. The bag retainers are mounted to the axles, just like the coil buckets. They do not have a sub-frame structure. It was a nice system because it adapted to the driving conditions, at high speed it would drop to the lowest position and at low speed you could position it to the highest position. The bags are roughly the same size as the bronco coils, probably would not be too much work to adapt the coil bucket to the bag.
nrramse
It would be bad for economy, but airing down the tires might help smooth that ride.
Also, I remember that Mitsubishi Monteros in the '80s had suspension seats. Or better yet, get one out of a Kenworth or Peterbilt :)
It wouldn't help the ride, but I wonder if a stiffer throttle spring would help the bobblehead problem.
B
bknbronco
North Metro, MN
Really?? I saw alot of guys run two springs and they look pretty stiff. (one inside the other). Would that throttle bumping be that easy to fix??
Something like this? Seems like a easy fix thats too good to be true??
Lmfp
Lake Charles, LA
I run a double spring on mine. Way to soft with just one. Also makes for a good safety if one breaks for some crazy reason.
