Since I got the 70 roadworthy, it just hasn't been much fun to drive.
It is all over the road. Since the entire front end and steering are new,
track bar and drag link angles are parallel, I was hoping there was no
caster in the front axle.
Anyway, I've had this camber/caster guage since about 92,
but never used it to measure caster before. Picked up a new
toy to help out. Rand alignment plates.
Specs here.
http://sherice.hortencia19.com/rand...blespadstie-rod-adjustment-set-of-2-big-sale/
They come with small ramps to drive up on, but the first time I tried
the ramps and plates just skidded down the lift runway.
Ended up cutting 2x6's to keep them put.
So I figured I'd try a supposed known quantity first, 14 stang
with 850 miles on it. Stang specs are
-.75 degree camber and 6.35 to 7.85 degrees caster (disturbing that
ford allows 1.5 degrees cross caster in this day and age, keeps them
from having to fix anything that is out, I guess %)). So the stang
goes up first.
Went to measure camber just for S&G, and realized I bought this guage
in a time when 17's were unheard of, let alone 18's. Had to add a
little extension.
It was dead on @ -.75, both sides.
Industry standard for steering wheel angle when measuring caster
is supposed to be 20 degrees. For some reason (maybe due to the
electric power steering), this thing just will not stay put when you shut
it off with the steering off center (on the plates anyway). So I went
out to the first lock on the steering column, which ended up about
18 degrees (close enough).
Results were
Drivers, left +2-1/8, right -2-3/16
Pass, left +2-1/2, right -2-1/4
Your supposed to add a negative to postive, and multiply by 1.5
So that gives me 6.46 caster drivers, 7.125 caster pass. close enough to make me think this might work.
So up goes the bronc.
Results
Camber, +1/2, both sides (can live with that)
Caster Drivers, Left-1/4, Right -2-3/8
Pass, Left, -1/4, Right -2-1/4
So pretty even at 3.2 degrees drivers and 3 degrees pass. Not the
zero or one degree I was hoping for, but room for improvement on a
rig with a 3.5 lift (using 7 degree bushings) and 33's I guess. About
what one would expect on a stock 77 axle since ford supposedly
added some caster in the later years.
You could do this on a relatively level floor without the plates or lift
too. I used level out a spot on any garage floor using newspaper,
a level and a long straight edge. Instructions show you can just make
marks on the floor for the caster part. A real cheap caster/camber
here.
http://www.toyheadauto.com/CasterCamberGauge.html
Specs here.
goes up first.
little extension.
Results were
Results
here.
