Rwedoneyet
- May 29, 2012
- 2
I am posting this because I am very frustrated. I have read the threads one by line as my build has been going on, and I have tried to use this site as a troubleshooting guide to solve my roadblock, but with no luck. I am so close to having my truck back on the road. *Any help ideas or comments would be welcome.
Let me start by stating I am not a Motörhead and don't understand *half of the jargon on this forum , *but I can try to explain where I am at with my problem.
I had a old junkyard motor that was old life support so I figured that I would freshen everything up.*I purchased rebuilt short block 302 roller engine which was bored 30 over. A New comp cam was installed(mild) , with other new and recycled parts from a 1995 302. I found 1995 GT 40 heads (donor block) and had them redone with new springs to match cam. Heads were polished or milled to remove rust? Engine and was assembled by a mechanic A. The engine was installed in my truck with new wires, plugs, timing chain and distributor and stuff by builder B. *It has a Howell TBI universal 2 barrel system on it brand new. *When we Turned the key it barely runs, once it starts to warm up*, it pops and backfires out of the carb.*All plugs and wires have spark. *Compression is 120-125 across all. Cant do test when engine is warm because *i cant get engine too run that long.No vacuum leak was detected . Timing chain was off a tooth -4 we thought that was the issue but nothing was different when we changed. *Took covers off valves and they look like they are working properly. It seems to get worse as it starts to warms up.*
Any ideas I am at a loss and could use so guidance.*
