Alright what's the secret guys? (aftermarket steering)
raleigh_bronco
I have aftermarket steering from BC's. So all you guys using BC's or Bulletproof heim steering etc...How are you guys mounting the steering stabilizer onto the oversized tubing because the stock mounting plate and U-Bolts don't fit over the tube OD.
What's the secret?
phred
Earth
get some larger u-bolts that will clear to DOM tubing. Either mod the existing bracket to accept the larger u-bolt or fab a new one. I added a couple set screws in the bracket to wedge the bracket against the DOM tubing once the u-bolts were tightened.
bmc69
My 'secret' is I do not run steering stabilizers. My solution fits perfect every time.;D :p
...sorry. Couldn't resist.;)
raleigh_bronco
raleigh_bronco
lol.
Thanks for sharing the knowledge guys. ;D
Looks like I need to buy a piece of steel and a mill.
TN1776
Try it without the stabilizer, seriously. I have never run a stabilizer after lifting, changing to BC steering, etc, and I don't think I need one. Get a professional alignment done and see where you end up. Then if you still think you need one, go with the larger u-bolts, etc.
raleigh_bronco
raleigh_bronco
It drives fine on the road, but I appreciate still having opposable thumbs after a day off road (with manual steering). ;D
I'll try to fab up a bracket, thanks. Anyone have pictures of their bracket?
