- Jun 19, 2014
- 4,079
Ok guys so my alternator isn't charging my battery. I talked to Paul about this earlier and will be testing my alternator later next week when I have time but I figured Id get enough info on this as possible. Im going to run a voltmeter test first, if the altenator is good I'll check my wiring. Right now I know my voltmeter is grounded to the body per the instructions via centech. Paul told me I should have a ground from the alternator to the voltage regulator as that's how ford did it. Paul thinks this probably wont solve the issue but I'm willing to give it a shot. My current set up is a basic stock 65 amp alternator, msd ready to run ignition and centech wiring harness. Everything is New. Just Trying to line up my trouble shooting ducks, so if battery and alternator test out good, suspect voltage regulator? or track down ghost draws by pulling fuses? TIA
CENTECH ALT DIAGRAM
ALTERNATOR
VOLTAVGE REG
CENTECH ALT DIAGRAM
ALTERNATOR
VOLTAVGE REG
