Just went to their site. Was it the Mustang Bronco 160amp alternator you bought, the one for $129.99US with the lifetime warranty?
If so here is the wiring you are required to run with it, as it is just a stock 3G:
For installing the 3G you will need two plugs. The first one is a small square plug that plugs into the side of the alternator, right near the battery connection. It is know as the "s" (stator) terminal. Some part no.'s for it are RCP 43313 or WAI 46-2804. This plug/wire needs to be soldered to the "S" terminal of the new regulator plug you are going to purchase. It is the middle wire on the regulator plug.
Regulator plug no.'s are RCP 43170, ACE SA-7125, or WAI 46-2802. Any rebuild shop should be able to cross those numbers. WAI will be better than RCP, as they are almost exclusively off shore, build it as cheap as possible. Though in the last 8 months WAI has been taking the same route. both average quality parts, finding high quality is getting hard to do. All the consumers fault as well, as they demand cheaper and cheaper prices. If you can find a NorthWest Regulator dealer near you, their plugs are great.
Anyway back to your regulator wiring. The middle wire goes to the "S" terminal plug. The "I" wire goes to the wire that went to the "I" terminal on your old regulator. The last terminal is "A", this is a battery sense line. You have an "A" terminal on your old regulator. You could also put an eyelet on it and attach it to the main battery output terminal on the alternator. Or if you really want to do it properly. Run a new wire directly back to the battery or as close to it as possible. The "A" circuit is battery sense, in other words it is how the regulator finds out what the voltage in the battery is. The more connections or the farther away you have it from the battery, the more chances you have of it giving the regulator faulty information.
Now that you have/or are about to, install the 130amp unit, you should also upgrade your main battery cable from the alternator to the battery. My website has a wire sizing chart you can download and print off.
If this doesn't help, give me a call at 1-888-214-7774. I will be here for another hour or so, and here from 8 to 5 EST tomorrow.
