Reynard , I'm gonna see if I can crunch some numbers and find out how much flow a 408 is going to require.
A lot of people are going to automatically default to these settings , thats not alway correct :
302 = 165/170 cc intake runners
347/351 = 185's or so
408 = 205 and up
as mentioned earlier , it all depends on what rpm range you expect to run the motor at and what your expectations are for it.
Regarding your question about intakes , a 408 is most likely going to be beyond the capabilities of the typical truck lower with a BC's adapter and Mustang upper.
Maybe a GT40 intake , quite easily a bigger intake than that.
I know the 302 GT40's can be cleaned up enough to flow up to 250 cfm , which is the same amount the TF TW (trickflow Twisted wedges) 170's flow , which would be a pretty decnt match for a motor that will require that amount of flow.
