lhinterman
Newbie
- Mar 25, 2020
- 34
I have an auto wire kit 510-317 and it was installed for me in my 66 bronco. This was a built from the ground up, no ford connections under the dash.
I just installed an ididit universal column(key in the dash, shift on the floor)
Now I have lost the turn signals, i am blowing fuses (turn signal and brake) . There is no power to the signals.
Is there a wire that powers up these circuits? That I may have disconnected. The Am Wire connector slides into the column connector with no problem. I have replaced the flashers, I have replaced the brake pressure switch, fixed the left rear pigtail..
When I started the column switchover, I had turn signals on three and none on the driver rear.
I assume I screwed it up, how do I get back to go??
