addicted
Im gathering parts for my NP 435 swap and I cant seem to get the straight scoop on a quality flywheel. I really dont want to run Chinese junk. Are there any brands out there that are for sure made in the USA? Thanks.
So are most people just running the the Taiwan and Chinese stuff?
Im not even sure what application I should be looking at. When I bought my NP 435 the seller threw in a Zoom clutch and a flywheel. He also gave me two bell housings. One is an aluminum one from a late 80s truck and the other one is an earlier cast iron version. The way he explained it to me was that the clutch is an 11", which is stronger than a 10", but wouldnt fit in the cast iron bell housing. Does that make sense? Now Im trying to decide if the larger clutch is worth the hassle because I need a hydraulic set up to make it work. I also dont know anything about Zoom clutches. The trans is going behind a moderately built 351W. Any opinions on the clutch size and brand? Who else makes a good quality clutch and is it worth running a hydraulic set up? Thanks for any info and advice. I want to do this right the first time.
original 351 flywheel and have it machined/resurfaced
