amp door jamb switch
nied4speed
what seems to be the best door jamb switch for the amp steps and where did you get them. bought 75104-01A kit. thanks
ntsqd
heratic car camper
Upper SoKA
No idea, but I would look at the jamb switches used on the FSB's as a place to start.
Several members have installed some kind of door jamb switch or another in their EB's over the years. But I'll be durned if I can remember what they used.
I think Steve83 had some kind of switch he used in his build.
Oh, and just as important as which switch, would be where to put it.
The EB door jambs and pillars are so oddly shaped and mated up, with strange access points to behind the sheet metal, that you might have to be very careful in placement.
In other words, measure fourteen times, drill once!
N
nied4speed
thanks for replies, duffy can you explain that grounding trigger or 12v interrupt trigger?
ntsqd
heratic car camper
Upper SoKA
So a simpler switch will work. Like this one: https://www.amazon.com/dp/B000C7XUU8/?tag=classicbroncos-20
N
nied4speed
thanks for the replies, I see what i might need will do some looking around for what fits my app.
