Amp Research power steps mod question
jasonmcc
Nola -> Utah
Question for those who have done the Amp retractable steps. Did you find it useful to use an override switch and if so what did you use? I've heard of someone utilizing the aux/main tank selector switch for an override switch. If you've done this could you explain that process? Thanks as always guys!
Audifan
jasonmcc
Nola -> Utah
What length did you guys cut your steps to? If you order the steps instead somewhere other than NEC what do you have to do to the kit to install? I have the brackets from NEC but purchased the step kit from Amazon.
bronco loco
It never ends
Long Island New York
When I have my dash redone, I had the radio opening, the ashtray and some holes welded. Unfortunately my aux/main switch was also welded. I was going to use a three way switch.
https://classicbroncos.com/forums/showthread.php?t=281805
