another bronco lean question
boxerharley
Centralia WA
Im confused, do i just loosen the caps on the radius arms or take them all the way off. EVERYTHING suspension wise is brand new... but I am sagging in the driver rear??
Do I just take the radius arms off and reinstall? Or just loosen everything and tighten down a certain way? When I drug the thing home from a field where it sat for 26 years it was leaning on the driver side, but the springs were SHOT. So I replaced EVERYTHING over the last few years and it leans, nothing like it did when I brought it home but still. Every once in a while it doesnt lean? What the heck, because 80% of the time it does?
Please help
thanks
jimmy18thing
I just installed all new parts also... I cleaned off the rust on the wedges and put some POR 15 on them... then I put some grease on the bushing and the wedges. I slowly tighted a couple turns at a time switching back a forth in an x pattern... That sure set it straight for me. I dont know if you would have to take it all apart or not but there some ideas for ya. Also I would check your body mounts and make sure they aren't broken, that could cause your EB to be leaning also. Hope that helps some
