So I have installed/reisnstalled the c bushings to the point where I have lost patience and the radius arms are within 1/4” of touching the floor at the same point and prayed it would not cause a problem.... Once I got the front axle into place and all bushings installed, I dropped the axle down on a pair of jack stands and one side remained about 1” off the jack stand. Is this the amount that my Bronco will lean?? Once I install the new coil springs will this variance be reduced..... I even added downward weight to the knuckle and loosened the c bushing bolts and re-tightened with the axle still pulling upward off the initial jack stand.. In a perfect world, would the axle sit completely level on jack stands which would equate to no lean?? Any help advice much appreciated.
