norm02
- Feb 8, 2016
- 336
Ahh, ok good.
But in doing this did you also remember to remove the front-most bolt holding the lower spring cup in place? If not then the cap can't fully release. There might also be a lot of stress on that bolt due to the bushings and the weight of the vehicle pushing it forward.
May not be enough to damage the bolt, but it still needs to be loosened to get the job done.
The measurements look fairly close? Almost 7 on the passenger side and what, about a 1/4" or so less than that on the driver's?
I didn’t know that I needed to loosen the spring cup bolt so I didn’t touch it. I loosened all of the bolts and re-torqued them 5 times. It’s now within an 1/8-1/4 of an inch so I’m ok with it the way it sits for the time being but the passenger side bushing bothers me a little.
I will probably take it apart again at some point but for now I’m going to drive it some and enjoy having it back home.
Yesterday
Today after playing with it for 4.5hrs
