Another bump in my engine assembly saga
Galt72
So, I started off wanting to install efi. I went a little further and grabbed some early 90's mustang roller heads and new cam. Well, I installed the water pump and began to install my old school alt. when I noticed the bolt hole in the head is twice the size of the stock long bolt that slides thru the alt. I look to the other side and notice the other head has a similar large bolt hole. I suspect that will give me trouble with my PS pump. %)
My questions are: Is there and easy fix for this. Some kind of bolt hole sleeve or do I have no choice but to convert to surp. setup.
And if I do convert, will I have to use a regular 5.0 waterpump or will the holes still match up on my stock bronco waterpump "which I just bought today".
Thanks for your help in advance;D
76 bronco J
there is a sleeve to neck the threads down from 5/8'' threads to I believe 3/8"-- the heads are drilled straight through for emissions then can be used on either side of the engine by placing the insert with inner threads for the accesories on one side then leaving the back open to thread on the emission stuff or capped off with a 5/8" threaded bolt-- if your heads were previously on a 1990 stang then you probably just installed them on your block opposite of the way they were on the mustang which is no big deal as long as your not using the exhaust air injection stuff-- look on the back of your heads and you will see the insert you need for the front
Galt72
Galt72
Hi and thanks, I just ran out and checked. Seems the inserts are not there either. Would my local Napa Parts or Kragen have them?
76 bronco J
I don't know if they would have them or not-- I looked around & pretty sure the ford part # is F4ZZ-6E086-A and I think you call them thermoactor plugs-- the bad thing is ford sells them for about 10 bucks a piece-- if you have some old heads laying around you may be able to remove them, I tried removing mine off the 76 heads for the new motor but I never could get them out-- remember for pluging the back of the heads it's much cheaper to use 5/8" threaded bolts -- it may be a little hard to install the plug or the bolt on the rear of the drivers side with the engine installed already cause it's pretty tight in that area
oldiron
Go to any reputable cylinder head repair shop and they should have cases of them for about 2.50 apiece.
Easiest fix you'll ever have.
Greg
Galt72
Galt72
Thanks for all your help guys. I guess I'll have to wait till monday for the machine shop to open.
