Gray035
So I have a 2100 two barrel on a 289, and I just discovered that it's leaking fuel out of the base of the carb. As far as I can tell it's coming through the gasket where the carb spacer meets the stock manifold. I just replaced that gasket, so I am surprised. I can't see any leaking from anywhere else on the carb. Any ideas about what the problem is? Do I need a thicker gasket? Could the spacer be warped?
