Ok I have the 302 EFI and the Exp serp set up. its not charging at all. My alt is brand new as of about 1 hr ago. Battery is at 12.07 with key off and running its the same. the alt is at 14.7. I have the centech/RJM harness combo. any help would be great. Not sure if i have something hooked up wrong.
Also do I need a seperate ground for the Alt? I figured it should be grounded pretty good thorough the mounts.
Thanks Tim
Thanks Tim
