Another Engine Bay Measurement
greatguy57078
I wish I had thought of it before I tore everything apart, but I did not. I need an exact measurement from the front edge of the frame horn to the firewall. When I say firewall, I mean where it is flat where the master cylinder bolts up. I am in the process of mocking up for a 4.6 DOHC Mark VIII engine, and would like to slide it back so I am as close to the floor shift as I can get. Even if I can pick up 1" it would be worth it to me. What can I say...I have short arms!
Thank you therd1 for the pic. I was looking for a Bronco with the front clip off!
7elk
Albuquerque
Front of firewall at where the master cylinder bolts to end of frame is 41 inches. The front is off of mine for a rebuild also. Hope this helps.
greatguy57078
greatguy57078
Is that exactly 41 inches? I wasn't getting any replies so I started another "if you have your front clip off" threads. I recieved another measurement of 41.5 there. I take it you measured straight front to back with nothing in the way...right?
greatguy57078
greatguy57078
Cool. Thank you for taking time to help me out. I do appreciate it!
