I just installed a 23 gallon tank on my 69 a couple of months ago (northwest tank from WH prob same one duff sells) due to a rusty rear tank, the tank itself sits about 3 inchs lower then the stock tank and about an inch away from both sides of the rear frame rails. It sits about an inch or so down fram the top of the tank to the bottom of the bronco tub you will need to remove the "saddle" brackets underneath the stock tank and the strap as they are not utilized with the new tank. The tank is a tight fit and needs to be inserted at an angle when you install it, not a hard job at all it utilized all the space where the stock tank was and it well worth the effort and cost, I also have dual exaust and had to move the pipe hangers over about an inch but not a big deal with adjustable brackets.....I would take a look at Chucks if you are planning on doing any lift or such as it is adjustable I have a 2.5 lift on this rig and the northwest tank fits just right.....
