MyBronco15
So, I installed a power brake conversion kit in my 71 with stock drum brakes and H block. As far as I can tell there is no air in the system but the pedal is indeed very soft the first couple inches then very hard. The brakes do work but not like they should, indknt believe anyway.
I took some.measirements to be a little more specific. The pedal sits 6 11/16 inches off of the floor now. Ot moves one half of an inch with no pressure I assume where the booster plunger engages master cylinder. Looks like I can take that out about 1/8 to adjust that no problem.
However, then you can feel the pedal slightly engage but pushes freely 1 7/8 inches with almost no feedback. Once it hits that plateau, brakes are very firm and stop well but pedal is very hard.
I had my seven year old son pump the brakes for me with the engine on and during that intial 2 inches of pedal the MC shoots fluid up and out of the resevoir and thenengine idle will change some but other than that things look right.
What do you think???
