Another quick Brake question
You mean the main H-block on the frame below the master cylinder? Or are you talking about something in the rear system specifically?
StnePny
Santa Monica, Ca.
There is no rear H - Block, the only H - Block is the front prop Valve, the rear union is attached to the rear hose (hard line fron frame to axle) which attaches the right & left rear brake line.
E
elkarcher
I remember taking a splitter valve or something like that off the rear. The same thing the breather hose is attatched to. Or am i thinking way off???
That's literally part of the brake flex-hose from the frame to the axle.
If it's separated, you need a new hose. The block screws to the axle housing with the tube-bolt that the vent line attaches too, and the two hard lines from the wheels screw into that.
May be time for a new hose then?
