AZbronco77
Hi Guys,
I know this has been gone over a million times, but Im still a little confused (doesen't take much). I found the attached pdf in another thread which is useful. However, I still do not understand if i need the second wire attached. I have a grant adapter with a new toms steering wheel going on a '77 column. There are 2 spots to connect a wire on the wheel. Does the grounded black wire from the grant plug to the connecter on directly beneath the horn button. And if so, what is the other plug for and where does it connect to? Viperwolf, I saw you were able to answer lots of steering wheel questions, maybe you could chime in?
Thanks guys!
Thanks guys!
