Here's an update on the Unser Brothers Stroppe Bronco. Actually with what I'm uncovering with the paint and the photos I have collected, I should probably call it something else, but Unser will do for now.
I've found where the old cage mounted as well as the spare tire bar support. I couldn't keep from doing some paint removal too and here are the results.
Like the Red Racer that Todd and I own, this one appears to have started life as a red roadster. Talking to Willie Stroppe he says none of them were roadsters to begin with (RR VIN is U13), but in any case, a red Bronco. As I remove layers, I'm finding it was red factory paint and had a blue lower paintjob at one time, so Red/Blue first. Also found some white on the lower body as well as the upper, but after that first Red/Blue. Finally it had the late 68-69 Stroppe paint scheme of Blue over Orange with a white stripe spearating the two colors at the belt line. Check out the photos.
Also found that the previous owner had covered over the original air baffles to the radiator. I removed the newer aluminum to expose the damaged original pieces. They've also been trimmed here and there, so I'll have to look at Red Racer and get an idea of what is missing. Only as a guide tho as the Red Racer got updated as she went whereas this one stayed roughly the same from '67-69, and then was left as-is, and possibly in wrecked condition til '81.
Lastly here's the exhaust coming thru the rocker. TOo cool. The PO did a turn down pipe before the rear bumper, so it brings fumes in. I'll try to remove the aux tank soon, and use some small mufflers and run the pipes back thru the body sooner than later.
