Anti Bling Fuel System upgrades, that only took me 10 months to do
DonsBolt
Chestnut Hill, Mass
Don't ask me why it took so long, as it has been sitting here for 10 months. I guess sometimes you have other more pressing things to do.
I made a post last year about where and what type of fuel pressure regulator to install. See this thread.
http://classicbroncos.com/forums/showthread.php?t=88564&highlight=fuel+pressure+regulator
Well latelly I have been having problems with my rear fuel bowl, or the needle and seat, causing the rear bowl to over flow. I replaced the rear needle and seat, and it worked ok for a week or two, but started doing it again.
I relocated my coil to the passenger side, made a bracket for the regulator, and mounted it up today. I can allready tell by a quick 15-20 minute drive that the carb is running better. I don't smell gas any more, and it pulls smoother and better from idle right up to 6 grand. Also the stumble I would get after idling for a while is gone.
I know it isn't mounted in the best spot, I made sure it is isolated from the heat with some phenolic spacers I made. The bracket I made sits about 1/2 inch away from the head, with two phenolic spacers, and the bracket that comes with the regulator is also isolated from the heat with two 1/4 inch phenolic spacers.
Here are the pics
In the 3rd picture you can also see the grounding block I installed a few weeks ago
DonsBolt
DonsBolt
Chestnut Hill, Mass
I had a gift certificate from Sumitt that was about to expire, so I ordered some Anti Bling heat protection, which now cover the braided stainless lines, and my AN fittings, it should also help keep the fuel as cool as possible.
I got some Thermo Tec Thermo-Shield Tape that can withstand temps up to 2000 degrees F and wrapped both sides of the bracket, and part of the Regulator.
I also got some Thermo Tec Heat Sleeves that cover the braided fuel lines. Since I had to run the fuel line that goes to the fuel pump under the steering box, I have the heat sleeve under the steering box, also from the fuel pump to the regulator, and from the regulator to the carb.
In the week since I first installed the regulator, the rear fuel bowl is maintaning the propper level. It doesn't smell like gas anymore, and seems to run a little smoother.
I also got two vertical mounting tabs for my wire seperators, so the two front seperators keep the spark plug wires away from the coil, and Fuel Pressure Regulator.
73stallion
Eugene, OR
that fire shield is good stuff. i put some on bill's speedo cable, and it's touching the exhaust. it has no problems at all!
