serial car restorer
Yes, I'll restore almost anything...
Posted by @Slowleak in a different thread:
Based on this, I've got a whopping 1° to 1.5° caster on my '69. Lift is now approximately 3-3.5", was about 1" when I got it and I had to lift it higher in front to match the rear.
So I'm going to guess I need new C-bushings. I suspect the ones in there now are still original. If so, I could probably get by nicely with 4° bushings. But if it already has degreed bushings in it, I'll need the 7° or more?
I'm thinking that 1° is in the ballpark for 3" lift with no other changes. Sound possible to you guys with more experience than I? Do I need to pull bushings on one side and see if I can figure out what they are? Or should I just say that more caster is better and just buy the 7° bushings and call it a day?
If you can measure camber then you can calculate the caster. Turn the steering wheel to the right and measure the camber. Then turn it to the left and measure the camber. Caster is the average of the two camber numbers.
