My 200ci in my 71 has a cracked block so I am looking at replacing the motor. I have a 250 from a 76 Maverick and want to know what to look out for when doing the swap. The 250 came out of a C-4 car but I want to use a manual tranny.
I believe the 250 and 170 length are basically the same - am I wrong?
If I could find one I would put it in my 74 and put a 5speed behind it! I think that would make a good DD!
Your only issue is the pan. I took the 170's and grafted it onto the 250 pan, took a little welding, but worked out perfect.
A 300 flywheel will work. I went with the centerforce II clutch and very pleased with it..
