Maybe not, but I think that's actually the goal here this time. Completely different worlds between overhead cams and pushrod engines and their strengths and weaknesses. Sometimes those things cross over, but often they work in different areas.
I'm guessing that fuel efficiency is pretty high on the list of things-to-achieve for this new engine. So that might (or might not?) put their tuning peaks at different rpm levels than the modular engines. Then again, maybe that peak rpm level was found to be at higher revs? After all, they did make the Mustang engine a real revver, and are putting smaller and smaller engines even into the trucks these days, so maybe the thought will be the same with the new one.
In fact, I'm showing my ignorance of the fact that I thought Ford had dropped the V10 long ago! I did not realize it was still being put into vehicles. Maybe I just had not been looking at the badges on the side of full-size vans and motorhomes lately.
As to fitting in a Bronco... I still say maybe.
It looks small, but it's got wider bore spacing than a Windsor, so may be in the realm of putting a 460 into an EB. Of course, with a more compact accessory drive system they might be able to compensate for that.
Let's hope they put as much thought into that as they did when they re-did the drive for the Explorers. Maybe even better!
