I have broken only one 28 spline axle in all these years and I can tell you that I was not easy on them at all . 302 + C4 + D-20 + 4.56 R&P and a mini spool with 16-35 X 15 Boggers , 35-12.50 X 17 BFG Kr and 35-14.50 X 17 GoodYear MTR . One thing that you might want to consider is this ... I know it can happen because I just experienced it last week . I put a full width 9" housing in my bronco and I had a center section all assembled and ready to go with a 31 spline mini spool inside , then I go to slide the fresh 31 spline axles in and they won't go . I am convinced that they sold me the wrong mini spool and I tear everything apart only to find out that the carrier is actually too small to allow the 31 spline axles to go in . So what I'm saying is before you go to the trouble of removing and re-instaling your 9" with 31 spline side gears , check the carrier to make sure it is big enough to slide the axles in . I hope it all works out for you !
Howiebilt
