I know it's only been a few days since I finished my M5R2 conversion but dang the shifter is HIGH. Maybe this is a product of the 97 and up shifter? It's almost as high as the steering wheel.
Was looking for advice on how to shorten the handle. Cut and weld? Has anyone used a Ranger R1 handle on a R2? I've read conflicting things over on Ranger Station about this. Seems the shifter internals (the stub that stick out of the Trans) are different between R1, R2 and late R2's (97 and up) so you can't swap the whole shifter but the upper part (the handle) that bolts to the stub should work. I say that because I find mop mention of it being different. Also the stick (above the boot) is just a shorter version of the F150 stick. Was hoping someone had tackled this issue.
Was thinking about going to the "yard" and finding a Ranger sick and using the upper (maybe the lower too) and putting it on the M5R2. I looked at the Hurst shifter......Those things are HIGH and not really in my budget. Looking for a more DIY approach.
Tim
Tim
